grizzlyls
So I finally got my baby back - July 5th was handed to the Mech! Least the hack job was set to new again. What I need to under stand though is a couple of things that discouraged me about the Prmary chain wear.
The mech stated that he cut himself on the sprocket which 'had been worn sharp' of the Primary chain I believe (was replacing the chains and tensionors with Christophers FP stuff). He believes this will fail sometime and I should replace soon. As we know that means the big job of pulling the front and all. So, how solid is the sprocket that the two chains use? What would likely go first, the chain or the sprocket? I dont hear any rattles, although he said he did when he started the car - but that may have been the new chain/stuff seating imo - would I hear something if failure is coming? Lastly, does this sound like normal wear, or is there something else causing this? Keep in mind grandpa maintained this car with documented routine maintenance.
My goal is to make a informed decision to just be aware of and be careful, or go ahead and attack this issue. Oh 2001 LS 101k miles.
Hmmm, interesting, full sentences, punctuation and questions with enough info to be clear........
