ford nut
Local nut case
It seems I always get the weird ones.
Here goes
Its on my 97, sometimes the drivers window works, sometimes it won't.
Yesterday we got into the 80s so yep my drivers window decided it won't go down.
I was thinking it was the switch...until yesterday.
I could hear a click click in the door panel when I hit the switch.
Then it was clicking without me hitting the switch.
I was at a red light, I also noticed it pulled the engine rpm down about 100 rpm each time it "clicked"
Frickin weird.
I got home and call Brandon, because he knows everything, or so he tells me.
He tells me how to get the door panel off and I found the source of the click.
Its coming from the black box that all the wiring goes to..it has your code on it for key-less entry.
I was going to see if I had power to the window motor but ran out of time, put the door panel back on and bingo...the dam window is working again.
The clicking is gone...the rpm stays the same on the engine.
Window is also stuck in fast mode it will only go up or down super fast...so if you want the window to be in a certain spot you have to keep pushing up then down real fast to try to get the dam thing to stop were you want it.
Anyone else ever run into this?
I guess next step is wait for the clickin to start...have the window fail and check for power at the window motor.
Or just replace this dam "magic" black box.
I hate this kind of crap.
Here goes
Frickin weird.
