power steering pump, door hinges
mista_g713
houston
i need to install a new power steering pump in my 99. it looks like a really tight fit in there, also looks like it will need to come out from under and i might have to remove the ac comp. The ps pump will cost me bout $100. how difficult is this to replace? Any ideas what it might cost to have the pump installed, or should i just go ahead and tackle it myself?
another thing i need some info on, my front pass. door is sagging and squeaks like crazy, i got a price from lincolnpartspeople.com for new hinges, $75 each for lower and $55 each for the uppers. Or I can buy just the pins and bushings at autozone for about $7 each set. Anyone else have this problem, did you have to change out the whole hinge or just pins?
Yes, you have to remove A/C compressor from under the car, then unbolt the power steering pump. Might have to remove power sterring pump pulley to put on new pump.
Brad.
