2002_lincolnLS
Custom User Title
The passenger side is leaking. It looks like it is dripping off of the bottom of the boot. It doesn't leak terribly unless you crank the wheel (can't recall off hand which way)
I noticed that a couple tubes push into the boot, where do these go? When I replaced the driver side inner outer tierod there was nothing in there for fluid to go to...
What could be leaking inside the boot that would cause it to be leaking out. It doesn't look like it is coming from the lines on the boot, but perhaps a tear on the bottom.
I am just trying to get an idea of what I even should look for or expect.
