Poly Upper and Lower Control Arm Bushings
cammerfe
Metro Detroit
This thread is to judge the interest in acquiring bushings as noted in the title above.
I have located steel shell poly-core suspension bushings in several sizes. In order to pursue this idea, it would be very helpful to know dimensions---the OD, ID, and length. If anyone has control arms available in such a way as to be able to get measurements it would be helpful.
A quick glance over the ordering information shows the bushings to cost $8.00-$15.00 each.
KS
I have the lowers, but it's hard to gauge the size of the bushing. It is most certainly a heavy press fit. At the very least I could get you the diameter of the hole it goes in on the lowers.
Very helpful, thanks. They ARE a heavy press fit so the dimensions do have to take the interference into account.
KS
