KyLSV8
How do you remove these weird pins under the hood. The ones that are on the cowl and right behind the grill.
The ones that hold the plastic cover over the radiator screw out; once they spin freely, pull up to remove.
To remove the pins that hold the cowl cover in place, push down (gently) on the center portion of the pin. It should go down one "click," maybe a few millimeters, then you'll be able to pull the pin out of the hole. To reinstall the pin, push the center pin out so it stands above the head of the pin, stick the pin back in the hole, and push the center pin down so it's flush with the head.
