After working on my car last weekend I noticed even after an hour of the engine not running and engine cover being removed the intake manifold and TB are still very hot to the touch. Phelonic spacers dont do much for EFI engines cause they 're normally fairly well tune in terms of flow but I feel heat is definetely an issue.
My thought would be to source phelonic material (not very dificult) and make a 3/8's spacer for the throttle body and also remove the coolant line that runs under it. And to do the same with the intake manifold not where it meets the heads but where the the aluminum spacers meet the plastic portion of the intake manifold again with a 3/8's spacer.Source a couple more of the pouches ford uses under the manifold to keep it cool.
Now to address the additional cfm capability added by the spacers I intend to source a 2nd throttle body and send it to http://www.maxbore.com/. Here iI assume he will be able to extract at least 3mm and this should compensate for the additional intake volume.
Please let me know your thoughts and if you forsee any problems
