rgorke
First, Happy 4th of July weekend!
Second, '04 V8 with 267,000 miles. I've got 1500 miles on my refixed transmission and the vehicle is running great, except for...
Third, car throws a P0420 code (catalyst below threshold Bank 1) every month or two. I also got a P0193 (High fuel pressure) a couple weeks back. The P0193 code only pops up when I go down a long 2 mile 7-8% grade after a slight incline on the freeway. If I monitor the fuel pressure while driving, it usually sits at 55 +/- 3.
I understand that the P0420 code could be the Cat or O2 sensor (upstream?). What are my options for further diagnosis? Switch O2 sensors between banks to see if issue follows sensor? That would determine if the issue is the O2 sensor or the cat, right?
Finally, what size is the O2 sensor tool, 303-476?
