I am glad to see that the LS community is finally starting to notice the mods that are actually available out there instead of just assuming that there is nothing.![]()
Lentech advertised a few months ago about a direct swap for the 5R55S to a 4R70W - but since seemed to have gone quite about it....
http://www.lentechautomatics.com/5r55home.html
A 5R55S might physically fit in your car, but the PCM won't be able to control it, so you won't be able to use it.will this fit im my 2000?
Level Ten builds the 5R55N transmissions too so there is always the option to have that built. The S,N,W trannies are so similar it is ridiculous so that stuff should be able to swap between all three without much problem if any.
If you can get an OBD-II PCM to control a CAN tranny, you must be pretty damn good.+1. I think it will really come down to the flash update of the ecm.
If you can get an OBD-II PCM to control a CAN tranny, you must be pretty damn good.![]()
