PCM Location?
Mexican3001
Car audio guru
Chicago
Im just wondering where the PCM is located in a 2000 lincoln ls v8... any info would help thanks
under the dash - on the passenger side - behind the glove box.
you have to pull off the plastic well cover and then look way up there with a flash light. It is held in with two 8mm bolts
thanks for the info still a few questions... can i get to the plugs by pulling off the golve box? how does that come out if so, or do i have to take the tire off by the passenger side n take off the inner fender cover to see it and the plugs? thanks im just trying to find the VSS wire since i can a CAN interface for the gray/black behind the radio
the PCM sticks through the firewall - with the connector side in the engine bay.
To get the connectors off - you have to remove the Cabin Air Filter, box and all, and the PCM connectors are under there.
