Passenger Window Headaches
StincolnLincoln
Somerset
Ok its me again i have changed this motor on my passenger side 3 times now in the last few mths and again another 1 bites the dust . Thank God there free replaced. I lubed the tracks and all even with the lube without the motor attached i can pull the window up and it stays up. Its not suppose to do that without the motor in. its suppose to just drop. Can anyone tell me where can i get another passenger track assembly beside the junk yard.
You're only good shot is a junk yard. It sounds like you need a new regulator assembly. I am assuming that you are slathering the entire assembly with White Lithium grease, right? Not the spray kind, the solid kind from a tube. Otherwise the track won't stay lubed very long.
