TheMachinist
So I can't seem to find any information on a situation specific to mine so I will post a new thread. It's a 2000 LS 5 speed manual. So on the way home from work today the "burned bulb" warning light came on. I got home and started poking around and its the passenger side brake light. The thing is, the turn signal works, and the night time dimmed version of the brake light works. Just when you press on the brake it doesn't get come on, or get brighter when you have the headlamps on. I've seen some pretty scary stuff about the REM on this deal and was praying that it isn't anything serious. I just finished putting in a new degas bottle, and window reg/motor unit in it. This is my daily driver and only vehicle and as it stands will have to take a vacation day tomorrow from work to try and fix it. Are the bulbs back there for the brake lamps a two stage bulb? Why would it come on with the headlamps on but not get brighter when you press the brake pedal? Any help would be greatly appreciated, thank you.
