Passenger door doesnt seal properly
ilovemyls
Goldsboro, NC
So I noticed a loud air leak coming from the passenger window on the highway, checked the seal on the door and around the door, everything looks fine. I then noticed that my door doesn't close as far as it should, its not flush with the car like the drivers side is. I slammed the door hard but still wont get flush, ive checked everthing, cant figure out what's wrong, any ideas let me know, I don't want to have to take it into the dealer
Same problem with my driver's door. It starts to whistle at 100mph.
Adjust the door striker plate on the B pillar, I replaced my Torque screws with M8-1.25X25 Phillips head to make it essayer to adjust. If you replace the T screws, do the one at a time, they go into a floating plate in the B pillar, you don't want it to drop away.
Agree with door striker plate adjustment & bolts. Hinges can be loosened & adjusted also!
