tireman
So i get the P0411 air pump incorrect flow message. The manual says check the pump motor and the manual says not serviceable. Yeah right. The motor is a simple electric motor 12V 2 amp. I tried 12v 1.75 amp and not enough power. Ok, used a air hose to clear out the electric motor, found long motor brushes for long life nice. Lots of dust build up from brushes. cleaned it all out, runs like a champ. The manual says it has a filter which is not serviceable, yeah right.
removed housing cover (1 screw) gently pryed off outer lid, and found filter.
Filter is cheap piece of foam, junk....ok take foam out, dust it off, put it back in. reinstall pump motor with new 1" hose clamps (2). reset cel light, now driving. Will update when issue solved.
