mharrison
I just got a CEL with code P0401 tonight.
According to my friend google:
A code P0401 most likely means one or more of the following has happened:
* The DPF (differential pressure) sensor is faulty and needs to be replaced
* There is a blockage in the EGR (most likely carbon buildup)
* The EGR valve is faulty
* The EGR valve may not be opening due to a lack of vaccuum
Has anyone else experienced this? Which is the most common problem? I recently ( about a month ago) pulled the top 1/2 of the engine apart to replace the PCV hose under the intake. (I have a V6.) Any thoughts on if this may have affected it or not?
