Overheating
Lincoln LS
  1. DrWulf
    DrWulf LVC Member
    12
    4
    Sep 21, 2020
    Maryland
    I have a 2006 Lincoln LS. I've had issues with the coolant system/overheating since i got the car (almost). I finally got the leaks to stop but the car keeps overheating. It doesnt over heat to the point qhere the needle goes all the way to red and it cools off relatively quick (within 1-2 minutes). Also, it only heats up when i drive it hard or when im driving at highway speeds for a period of time. Regular city driving is fine. A couple hard pulls its fine. Also, i had the thermostat, coolant reservoir, hoses, and water pump fixed. I also flushed the system.
    Im not sure what could be causing the car to overheat. Maybe a head gasket? Radiator was fine last it was checked (past couple months). I had a trusted master mechanic perform most of the work as well as look over then entire system. Any help/advice will be appreciated. Thank you.
    Edit: the car will overheat all the way if i keep driving it hard. I usually turn the heat on max and chill out to get the car to cool down. The needle usually only moves a couple millimeters when heating up but on occasion is does heat up a bit more.
    And yes, there is sufficient coolant in the system. Ive also tried bleeding the system so at least most of the time i know theres no air trapped in the system. I will add there is a bit more water in the system than coolant. Maybe 70:30 water to coolant ratio. Thats jus because i needed to put something in there unless i wanted to be stuck on the side of the road due to a coolant leak thats fixed now.
  2. HRLNKN
    HRLNKN Well-Known LVC Member
    259
    24
    Jan 8, 2010
    USA
    I almost positive you've got an air pocket still in your system. These cars are notorious for being hard to bleed
  3. DrWulf
    DrWulf LVC Member
    12
    4
    Sep 21, 2020
    Maryland
    Okay, ill see what i can do about bleeding it. I might jus take it back to the mechanic if i cant do it to see if he can.
  4. HRLNKN
    259
    24
    Jan 8, 2010
    USA
    Good idea. Also, make sure you're using the correct coolant & mix ratio. Strangely enough it does make a difference
  5. DrWulf
    DrWulf LVC Member
    12
    4
    Sep 21, 2020
    Maryland
    Ive been using the typical autozone universal coolant. I jus read that, apparently, these cars arent meant to use that. Ford recommends Motorcraft gold. Im gonna try that see if that helps.
  6. HRLNKN
    259
    24
    Jan 8, 2010
    USA
    The coolant matters most with regards to mixing in the system. If you've had all the coolant replaced by the universal stuff, you should be ok. Just remember, mixing is very bad (OATS & non OATS). It'll make gunk in your system. Just Google for pics of the carnage. Avoid that BS at all costs
  7. HRLNKN
    259
    24
    Jan 8, 2010
    USA
    Seriously, I'm thinking you still got some air in your system. The fact that it takes you driving it hard to bring it out is what I'm going on
  8. DrWulf
    DrWulf LVC Member
    12
    4
    Sep 21, 2020
    Maryland
    Okay, thanks for helping me out. I truly appreciate it
    • Like Like x 1
    • DrWulf
      DrWulf LVC Member
      12
      4
      Sep 21, 2020
      Maryland
      • Like Like x 1
      • 04_Sport_LS
        04_Sport_LS Dedicated LVC Member
        3,677
        447
        Jun 12, 2012
        Somewhere around Lake Erie
        Motorcraft Gold or Zerex G-05 would be best. While it is possible that you still have some air in the system... the 70/30 mix is probably the issue.
        A 50/50 mix provides boil over protection to 265 degrees.
        Your 70/30 mix is only good to around 230... which is where the LS runs during NORMAL driving.
        • Agree Agree x 2
        • 04_Sport_LS
          3,677
          447
          Jun 12, 2012
          Remember... the engine is all aluminum. Get it too hot, and you'll be replacing it.
          • Like Like x 1
          • Agree Agree x 1
          • DrWulf
            DrWulf LVC Member
            12
            4
            Sep 21, 2020
            Maryland
            Yea i was thinking that was playing a major role. Im replacing the coolant today with a proper 50/50 mix of Zerex G 05
            • Like Like x 1
            • MKVIIILSC
              MKVIIILSC LVC Member
              15
              Oct 4, 2020
              Forest Grove, Oregon
              So you'll have the air locking issue.
              Simply cycling the engine temp from hot to cold then refill the coolant reservoir is how I did it. (Cycling several times that is.)
            • DrWulf
              DrWulf LVC Member
              12
              4
              Sep 21, 2020
              Maryland
              I flushed my system again, filled with Zerex g-05 (properly diluted this time lol) and bled my system properly. Car hasnt overheated since. But lucky me.... my starter jus went bad smh
              • Like Like x 1
              • DeviLSh
                DeviLSh Dedicated LVC Member
                607
                124
                Apr 26, 2007
                Des Plaines
                LS ownership = whack-a-mole :D
                • Like Like x 2
                • Agree Agree x 1
                • Robert Crain
                  Robert Crain Active LVC Member
                  94
                  23
                  Feb 28, 2019
                  New England
                  For sure, your fix starts with a 50/50 mix of the gold coolant. When you go to bleed the system, have the front end of your car pointing downhill. That way the air bleed screw is is in a high position relative to the rest of the coolant system and that allows the air to escape much easier. I do this every time I bleed my system and I never have any trapped air problems.
                  • Agree Agree x 2
                  • SteveOwens
                    SteveOwens Active LVC Member
                    96
                    20
                    Jun 24, 2015
                    Magnolia
                    I had plumbed the the bleed line into the degas tank to bleed the air out only requiring opening the cap and seeing the fluid level lower. Problem with that is the plastic tank wasn't made to be in the circuit thermally. It failed thru cracking. I had sourced a China made aluminum degas tanks ~$100. Canton can make one thru investigating. I have a radiator bring made by Don Davis radiators around $1100 to handle the heat due in Jan-Feb.
                  • DeviLSh
                    607
                    124
                    Apr 26, 2007
                    Des Plaines
                    Or back up on ramps if you aren't blessed with hilly land.
                    When I bleed, I cut a water bottle in half and place the capped half under the bleed. Did I miss something in my years of LS ownership, am I supposed to be letting the bleed line drip into the degas tank? I have always thought the bleed location was awkwardly placed and prone to making a mess without my bottle technique. But the manual says to put the cap on so I assumed I was doing it correctly.
                    Either way - 50/50 Gold + proper bleeding is essential. I usually go through 2-3 cold starts to operating temp cycles before I even drive the car after a coolant repair.
                    • Like Like x 1
                    • Agree Agree x 1
                    • SteveOwens
                      96
                      20
                      Jun 24, 2015
                      Magnolia
                      For roadside bleeds which happened often, a cap twist is much easier. When I get my radiator installed pictures will follow.
                      • Like Like x 1
                      • DrWulf
                        DrWulf LVC Member
                        12
                        4
                        Sep 21, 2020
                        Maryland
                        Hey, everyone another problem with the cooling system. My thermostat housing cracked again. At this point im not sure what could be causing my cooling system to keep failing. Mechanic says the head gasket could be blown and thats why other parts are failing. Is this true? The only two things that havent been replaced are the head gaskets and the radiatior. Could the radiator going bad cause other parts to break?
                      • joegr
                        joegr Dedicated LVC Member
                        20,365
                        1,647
                        Dec 10, 2005
                        Gulfport
                        Not the head gasket. That's the number one miss-diagnosed LS problem, or close to it. The symptoms make it look like that, but it isn't.
                        Are you using new OEM parts?
                        Are you installing according to the factory service manual (correct torque and sequence)?
                        Are you following the filling and bleeding procedure to the letter?
                        I wouldn't be surprised at all if you need a new radiator. Look at the top front of the passenger side tank for signs of a crack. Still, that won't be the cause of other failures.
                        If your system really is going over pressure (I don't think it is), then the only part to be at fault would be the cap on the degas tank. That's where the pressure regulator is.
                        Also, check your engine mounts. Maybe the engine is moving around too much and damaging the parts.
                        • Like Like x 1
                        • Agree Agree x 1
                        • SteveOwens
                          96
                          20
                          Jun 24, 2015
                          Magnolia
                          Ultraviolet coolant dye and the glasses to see the leak is one method to diagnose where the leak is located. After an air bleed from system, i would place white poster board under the engine. If the there is a leak you can trace it. An example, the throttle body preheat hose that routes to the engine center Vee
                          • Like Like x 1
                          • Agree Agree x 1
                          • DrWulf
                            DrWulf LVC Member
                            12
                            4
                            Sep 21, 2020
                            Maryland
                            All OEM parts are being used and installed properly. Ive also Bled the system to the letter. I do believe i may need a new Degas cap. I went to check my coolant level a week or so ago and it was very loose yet no coolant was coming out. I will likely get the radiator replaced as well. Hopefully those two will end my coolant problems. I will say, its become a headache and ive been seriously considering selling it and getting a new car.
                          • DrWulf
                            DrWulf LVC Member
                            12
                            4
                            Sep 21, 2020
                            Maryland
                          • DrWulf
                            DrWulf LVC Member
                            12
                            4
                            Sep 21, 2020
                            Maryland
                            I will be checking the mounts. I never thought about thats as a potential problem but it makes a ton of sense
                          Share This Page
