studebaker1962
hi agian,
i had a problem a couple weeks ago with a broken heater control valve on my 94 deville. fixed that, replaced water pump as well. the car was running great for about a week and a half,then i parked the car after driving for about 30 minutes, went back to get in it a couple hours later and had a basketball size puddle of coolant under the passenger side front part of the hood ( right under side light marker) it looks like it may be coming from the bottom right part of the water pump but everything below the pump is wet so its real heard to tell. is there anything else that could be slowly leaking? i checked all the hoses (upper,lower radiator,replaced all heater hoses and overflow hose) i am at a dead end..any help is appreciated thank you.
