Hey guys, anyone had problem with the distance till empty alarm chiming when you have more than enough gas? Is there a way to calibrate this or is it just broke?
They all do it, you can pull it and clean the contacts on the unit with rubbin alcohol and a qtip or try techron gas from chevron or the techron fuel injection cleaner, contains a chemical that helps get rid of the residue on the sender that causes this.
