kracker
ok 94 mark viii. put the obd1 test scanner on it it cycles thru to the compressor but stops. i am getting a hard fault meaning the check air ride comes on right after you turn the key on.i have swaped the computers with mine and the relays as well as the compressor. i am thinking it is a height sensor. since the next test is the heights sensor test in the sequence but it does not vent after the compressor test. it does vent before the compressor test any idea's
