Oil on coil packs
Mike Pizzuto
Newington, Connecticut
Pulled 2 coils out of Mark viii 98 and noticed oil was on them. Would that be a bad valve cover gasket or was the spark plug not put in correctly? Also have misfire on that side
Depends on how much oil was down there. If it was a little I wouldn't be too concerned. That is a sign that the little circular gaskets between the valve cover and head are a little worn. Honestly, if it's not a lot dry them up and check them after a few thousand miles. Was the misfire on one of the cylinders that had oil in it?
.02
.02
After rescanning , only a few misfires from cylinder 4,5,6 but a lot on cylinder 1, going to check fuel line under fuel filter looked a bit kinked last time but going to check it when I get the chance. The oil was on the back 2 coils if your lookin at the car from the front on right side where it says "intech V8". Cars running lean on left side, when driving runs real bad
.02
On a side note would a dirty MAF sensor cause car to run lean/rich on bank 1
If a MAF is faulty it would effect both banks. I bet you dropped that #1 coil. Swap it out with a different cyl and see if the misfire follows.
