Hi everyone,
I was wondering if anyone has seen this is their V8: I have oil accumulating in the air filter box. It is coming back through the air intake, weeping through the filter and draining through the bottom of the filter box.
Normally I'd assume this was a PCV issue, but from my understanding the AJV8 engine doesn't use a PCV, and instead has some sort of "load breather" orifice. I've read on a few Jaguar forums that this clogs at times and causes blowby similar to a failed PCV, however I've never come across anything specific to the LS. Presumably they're similar as its a Jaguar engine, but with all the engine variants out there I don't want to assume too much.
This seems to be treated as either an easy, quick fix or an engine death sentence on Jaguar forums. Has anyone come across some clear instructions for trying to clean out this breather? I'd love to keep the car running a little longer, however it has too many other little issues to start having a mechanic throw ideas at it.
Thanks!
Kevin
Thanks!
Kevin
