Ohe more wheel question
Buckeye68
OH
Ok so I picked a set of wheels. The rears are 18x9.5 with a 40mm offset (figure I might need to use a wheels spacer to make it fit perfect. But the fronts I am unsure if I should go with the 18x8's in 40mm offset or if I can rock the 9.5's on there as well. So the question is how much room is up front on a 98?
nobody knows how much tire and wheels can be stuffed up front?
