Odd Air Ride issue.
SATURN5
Dr. Frankenstang
in the shop
Compressor seems to not pump when the temps are in the 90's.... Works great otherwise.
Ideas? I've got a fill nipple, so I just used the house compressor and shut off the air ride until the temps drop.. But this is strange..
do the pump have a thermal cut off in the circuit?
Seals/scored cylinder or maybe the solenoid is sticking.
Give Eddie a call at American Air Suspension. Something is not right. I would guess the added ambient heat is casusing a crack or leak in the system to open up. If the pump is running the air is going somewhere.
More than likely issue is moisture related, and possibly the vent solenoid is on its way out.
I don't use the original vent valve.
