October Specials: DI Clay Bar & Foamaster II Foam Gun PLUS Menzerna Give Away
Detailed Image
Albany
OCTOBER SPECIALS
1.) DI Accessories Gentle Fine Grade Clay - 180 g Reg $17.99, Sale Price $12.99
This high quality clay bar is one of the absolute best values on the market. It helps you deep clean the paint and keep it free from stubborn contaminants. This allows the sealant and wax to bond to the paint better giving you a deeper shine that lasts longer. Use it just before your winter prep to get the maximum durability.
2.) DI Packages Foamaster II Advanced Kit Reg $59.99, Sale Price $44.99
This foam gun screws right on to any hose and allows you to spray foam all over your paint while washing. This makes washing go much faster and it's safer than traditional washing. When you spray the foam on the car it starts to loosen surface contaminants right away, instead of waiting for a soaking wet sponge. Also lets just be honest it's way more fun to use as well. Save 25% off and pick one up today!
Free Contest
For the October - November FREE Contest we are giving away a heavy, medium and light polish with a special follow up product. The polishes are great at removing swirls, very fine scratches, oxidation and more to restore a flawless looking clear coat. After you are done wipe down the surface with the Menzerna Top Inspection, which removes any oils or remaining residue. This leaves the paint totally clean and smooth so it's perfectly ready to be sealed or waxed. Here is everything included in this contest:
Menzerna Power Gloss - 16 oz
Menzerna Power Finish PO203S - 16 oz
Menzerna PO106FA Nano Polish (Super Finish) - 16 oz
Menzerna Top Inspection Spray - 500 ml
Don't delay sign up for the contest today! Again it's totally free and it only takes about 1 - 2 minutes. If you have any questions please let me know I would be happy to help.
Greg @ Detailed Image
I just wanted to remind you that the sale on our Clay Bar and Foam Gun expire on 10/31 at midnight EST. If you have any questions or if you would like a recommendation please let me know.
Greg @ DI
Wow... that is rediculously cheap for that clay...
How does it compare to CG med.?
This is a fine grade clay bar so it's designed to remove lighter build ups. I use CG medium grade or other medium grade clay bar for paint or clear coat over spray, tar and really stubborn build ups. The CG's, our clay bar, etc. are all from the maker of Clay Magic, they essentially are the only mfg in town. So yes this is a great deal on a quality clay bar that I use personally.
Greg @ DI
