McMkVIII94
On my '94, does the computer "store" data such as: cylinders with an intermittent miss and other info that happens while the car is running?
I know nothing about car computers, but trying to learn as fast as I can.
Saturday, I took my car to a sand pit I do some contract work for, and the maintenance supervisor hooked up their Actron CP9185. We only had time for a KOEO test, and got the following codes:
111 No Faults detected KOEO test
157 Mfg. specific code (found out here that's MAF voltage)
634 Manual lever position voltage out of range in Park
Nothing regarding a cylinder skip or like that... do I need a KOER test to tell me that info?
I'm having a low RPM skip under load, mostly when pulling a grade at ~60 in OD... upshift to 3rd, RPMs go up to ~23-2400, smooths right out. I've Seafoamed it once, changed fuel filter, trans. filter and fluid (to Mercon V), 1-2 accumulator upgrade, and spark plugs (to Autolite 764). Plug wires are next, after I figure out which ones to buy, and save up a little extra coin for them.
Also, I found a Equus 3145 Ford Digital Code Reader for $25... worth it, or no?
TIA, I always try to search first and not ask repeat questions... but didn't find much about OBD-1.
