I could not find the answer, I hope someone can help....
We did remove all 3 cats on my LSC 1995, and mounted some nice Raptors mufflers, great sound and hopefully better fuel eco and perhaps a few hp? We put the O2 sensors back in the same place as before, just now on new pipe, no cats. Note this car only has 2 O2 in front of the cats (thanks Chris2523.
When driving from the garage everything was just fine, BUT after few miles, the "Check Engine" light came on
The engine is fine.
After 1 hour at home I did start the engine again, and no "Check Engine" light. I went for a short drive and after 3 minutes drive it came on again... I stopped the engine for few sec and started again, no light, then after 2-3 min drive it came again, etc...
- I have not yet found a error code for this, but will write it here when I have, but again it could be difficult to do as the error only occurs after driving for 3 min...
- Anyone here have an idea what this could be?
I did the same thing on my Audi TT few years ago, I remember we moved the O2 sensors a little bit from the pipe until it "fooled" the computer. Can we do the same here, will it work?
Will this error message have any affect on the fuel consumption? I presume the engine will be fine even this light is on?
Well, this is getting more and more strange...I did get the codes:
177:Oxygen sensor not switching - system is or was lean - Single, Right or Rear HO2S - Fuel control
172:Oxygen sensor not switching - system was rich Left or Front HO2S - Fuel control
332: EGR did not open/respond during test or if memory code, did not open intermittantly - EVR or PFE
Any help on this GREATLY appreciated !
The engine is fine.
