Glorywagon
You all know awhile back i replaced the air ride with coil springs on rear. Boy they sure do rattle and when you hit a bump the left rear squeaks real bad. Any suggestions besides reinstalling air ride. Thanks
Yes Eddie"s kit.Maybe needs shocks.If he has Eddie's kit then he should have metal plates at top, but nothing on the bottom.
When i fitted forum member chico's kit, i was puzzled by the lack of bottom rubber pad - Chico called American Air and they said its normal - new kits don't have it.
Wonder why they didn't come with any. They are really noisey.They show the rubber pad for the lower control arm in pictures, but when I put them in my old 95 for my old man last year, they didn't come with them. Luckily he had these rubberized over mitt things that I used instead. Works like a charm still!
Strutmasters 1.5" Lowered kit on my car. No noise problems at all.
Did you install the rubber isolators that are supposed to sit under the springs?
Did you rotate the springs to their proper orientation?
Are you sure you didn't install the springs upside down?
the springs are carrying the yatch around, theyre not rattling, something else is, bushing somewhere, shock mount, maybe sway bar link. And my kit came with the little rubber pad thingys.......
Where do I get the rubber at.? How do you install it. The directions didn't say anything about it. Wonder why the kit didn't include them.His and mine didn't, and if you put those suckers in without an rubber in between the coil and control arm, it's gonna make noise.
Go buy some thick rubber sheet. Cut it to approximately 5" x 5". Install under springs with proper spring seating position and enjoy.
Call Eddie. He'll walk you thru it.
