Noise coming from rear
Chadly
Camp Lejeune, NC
Its on the 97 w/ 154K miles. Kinda sounds like a grinding or vibrating noise. I hear it when I am coasting or braking, not when accelerating or even just barely on the gas. I am worried its a wheel bearing, but hoping my brake calliper just came loose after my recent brake job. Any ideas or suggestions?
Sounds like a brake issue to me. Normally I would say pads but you implied you just did the brakes? Did you do them yourself or have them done? Did you turn the rotors or replace them? How did youcompress the piston?
You could jack the rear up and putthe car in neutral. See what side its coming from and see if it makes the sound with the calipers removed.
Side note, I have seen a couple members have something rubbing on the drive shaft. Make sure nothing is.
Got it figured out. Turns out I had 3 loose lugnuts! Pretty scray considering I only have 4 on that wheel right now LOL. Thanks for the help, turned out to be an easy fix.
