AVMIII
Above apparently a function of fuses 4, 10, 16 in the instrument panel fuse panel, which in turn are controlled by delay relay 1 and fuse 14 in the engine compartment fuse panel. All fuses test good, and no 12 volt power detected from any of the fuse positions. If no power to fuse 14 in engine compartment fuse panel, what’s further up the chain? Any other relays or fusible links etc?
I doubt if any battery/ alternator problems responsible due to the selectivity of just these systems not working. Electric mirrors and windows work BTW.
I’m about ready to hit the dealer so could use some help!
