All is such a small word.
All in a sentence is easy to overlook while comparing OEM pricing.
All or nothing cooling system re&re, degas included.
All plastics much be replaced.
System must be air tight closed loop and able to get up to temp without over heating any further from any component degrading. Rad and Pump can be ignored on replacement. Be wise and put in new DCCV and Aux flow pump during rebuild. 1st GEN use JAG Aluminum T-housing with Ford T upgrade.
It degrades and become brittle over time. Replacing one part only causes further failures, In-completes or call backs. More then one as in
All parts are needed.
Degas bottle dries out and forms cracks on the backsides, it's exposed to constant coolant heat cycling. re&re OEM bottle w/ cap required.
All Plastics needs to be refreshed. System needs to be able to be bled fully and correctly. Saving in labor rates, you can do
All this work yourself at home with knowledge and tools.
It's understood folks be in a pinch and budgets don't comply, but it is what it is ... An old degrading plastic LS cooling system.
