no heat
jkastell
Staten Island
i know this has been discussed 1,000 times before. I have a 98 LSC and I have no heat. I changed the A/C temp sensor in the middle of the dash but still has no heat. Probably the blend door motor. How do you check if that is the problem and where do i find out how to change it. THanks for your help. Anybody want to buy a 98 LSC 91,000 miles on it and needs a blend door motor. Otherwise in excellent shape.
I have blower motor operation but just cold air coming out. THe heat also was not that good this winter and now only cold. I have not used the car because i just got a bike and now that the wether is so :q:q:q:qty i had to use it and i have no hot air at all. The car is dark gray with gray interior. In very good shape new tires, new upper arms, new rear shocks, nice system in it and very clean. I would like to get between $5000 and $5500. If i have to i will fix the heat i should be able to handle it i work on dump trucks and heavy equipment and have been an mechanic all my life so just have to get the part and find the time to do it.
One little problem and you are ready to get rid of it!?!?!
What the hell?!?!
Come on... fix it and enjoy it
