no heat
onyx
Tucson
i have a 1982 Mark VI
just got the original R134 A/C working. blows like a champ.
now i'm going to start on the heat. i can feel a little warmth coming from the vent, but obviously nothing is blowing out. the fan works, but im thinking it could be something deeper.
are there any known problems for a heater core or the heater blower going out. i know the car is old. just trying to figure out where to start.
torquemonkey
Surprise, AZ
Could be a clogged heater core, air trapped in the system or IIRC there may be a vacuum operated valve under the hood to not the coolant flow into the cabin area untill the heater switch has been turned on. If this vlave is on a VI, you would find it in-line with a heater hose goiing into the firewall.
My .02
smilesmo65556
richland
need help heater not working blows only cold air been told is blend door problem on my 1988 caddy eldorao where is this at help please have kids and no heat
UltimateLS
Carrollton
I have problems with switching from heat to cold... Air stays hot all the time... Car gives code B1262 B1263 put in scan tool... Could anyone pinpoint the actual switch or the cause of this fault?
UltimateLS
Carrollton
I have problems with switching from heat to cold... Air stays hot all the time... Car gives code B1262 B1263 put in scan tool... Could anyone pinpoint the actual switch or the cause of this fault? I've already changed the heater control valve... Didn't fix the problem...
