OK, so I have this 2000 LS V8 I bought last week. On the drive home it seemed to have heat in the cabin. Well a few days ago there was no heat on the drivers side and not too much on the passenger side. Now there is almost no heat on the passenger side and none at all on the drivers side.
I replaced the DCCV and also the old one was working fine. When switched to heat both lines feeding the cores are hot. The return line is also hot. There are no codes in the DTAC and the coolant level is at the normal range in the surge tank. Since there is no blend door and I have heat on both the feed and return lines I am at a loss.
Any ideas?
Any ideas?
