mike_57
Hello, I just picked up a 2002 3.0 with a manual. The AC wasn’t blowing cold so I figured it needed a recharge, went to do that put the pressures were fine so I didn’t add more, wasted $40 but that’s how it goes.
Then yesterday morning it was cold enough to turn on the heat.. and that didn’t work. Felt like it was just blowing the outside air into the car.
I ran the self diag on the climate control and that didn’t give me any codes, just a glitched out screen when it was done.
Found out the dccv is a problem on these so I checked that fuse, it’s good.
So in conclusion do you guys think I should start with replace the dccv or maybe should I try a heater core flush? Or should I start elsewhere?
Anyone else had the experience of neither heat or ac functioning at the same time?
