In addition to my friend with the 97 LSC, another friend with a Mustang runs a HSW kit. The only problem any of us have had is the Stang guy's pressure gauge decided to leak nitrous out the back of it - of course right after a refill, $40 out the window. However it was probably due to something in his trunk running into it IMO, his trunk is always full of crap. Other than that we have all been happy. The LSC guy is real happy, I always used to pull him (I have gears, he has a stall,) but when the switch is flipped it's a lot different now![]()
Sounds like a good idea. I set mine at 6800 and spray thru the shift. You may not want to due that being a wet kit and no shift kit for the trans. You can always turn the kit off manually at the shifts and turn back on after the shift.
Do you spray right off the line?
No I never spray the at the line. Wait until the rpm's are over 3500. Basically launch the car and then let it eat.
Doesn't that rpm what your car launchs at anyway with the stall converter??
