Howdy
I’m Caleb. New member here. New owner of a 2003 Lincoln LS!
Noticed a lot of knowledge in here, and notibly admired Joegr
bought car for $500. Turns over, doesn’t start. Previous owner replaced coils, fuel pump, mufflers, and so on to no avail.
First I noticed the alarm light was flashing really fast, which I’m presuming from research would prevent from starting. I also noticed when turning key to run, I did not hear fuel pump engage. Inertia trigger checked and is depressed.
did some checking - found that PCM diode was bad, and after placing a jumper wire in its place, the flashing light for alarm went away. Also found that Fuel Pump Motor Diode in the trunk was bad, and also with the jumper, I now hear fuel pump kick in!
going to pick up Diodes from ford dealership today and will update after that. Hoping that solves a problem.
I also noticed a large parasitic draw, between 4-6 Amps!
I began chasing this down. When pulling a 40AMP block fused Albee’s P/JB in the back, I found that it controlled 7-8 different fuses in the passenger compartment fuse box. Narrowed it down to 3 fuses, which are 7, 18, and 20. Not sure what’s causing the draw on these or if I can run without them, but one killed the remote lock/unlock. With all 3 removed I now have 0.04 amp draw. With the anti theft one in, (#7) I still Had 0.2 Amps draw.
Any advice appreciated! Feel free to hop along my journey!
