New FREE Car Care Product every week at DetailedImage.com
Detailed Image
Albany
New Weekly Special At www.DetailedImage.com
This week through 1/4/2011 (EST) you can get the DI Accessories Gentle Fine Grade Clay 100g for free with a purchase over $30 (no including s/h or tax). You don't need to add this item to your cart, just use the coupon code WSGENTL5210 to automatically get this free item (limit one coupon code per order).
100 g Regular Price $10.99
  • Safely and effectively remove tar, sap, paint over spray and more
  • Fine grade clay bars will not mar your finish when used properly
  • We recommend using Dodo Juice Born Slippy as your clay lube
Let me know if you have any questions.
Detailed Image
Albany
This week through 1/11/2011 (EST) you can get the DI Accessories E-Z Detail Brush for free with a purchase over $90 (no including s/h or tax). You don't need to add this item to your cart, just use the coupon code WSEZDET0111 to automatically get this free item (limit one coupon code per order).
Mini Size Price $14.99
  • Mentioned as an essential tool professionals use in Autoweek magazine
  • The professionals choice for a wheel brush to clean the inner barrels of your wheels
  • Works great with soap and water for maintaining wheels or with a wheel cleaner for heavier cleaning
  • Turns a good wheel detail into an exceptional one that really shines with open spoke wheel designs
  • Can also be used in your engine bay to agitate contamination after degreasing
Detailed Image
Albany
This week's Weekly Special is DI Accessories Ultra Fine Clay Bar - 200 g.
Use Coupon Code WSULTRA0611 to receive it for Free. A $18.99 value! Min spend $55. Offer ends 2/15/11 at 11:59 PM EST.
  • Our finest grade clay bar to ensure minimal marring or swirls added
  • Perfect clay bar for those who regularly maintain their vehicles
Detailed Image
Albany
This week's Weekly Special is Meguiar's Ultra Finishing Polish M205 - 32 oz.
Use Coupon Code WSULTRA0711 to receive it for Free. A $27.99 value! Min spend $165. Offer ends 2/22/11 at 11:59 PM EST.
  • Removes swirls and light imperfections on any type of paint
  • Finishes down haze, hologram and marring free
  • Perfect follow up to Meguiar's Ultra Cut Compound 105
  • Commonly used with a white polishing pad or a black finishing pad
Detailed Image
Albany
This week's Weekly Special is Leatherique Prestine Clean - 16 oz.
Use Coupon Code WSPREST0811 to receive it for Free. A $19.99 value! Min spend $150. Offer ends 3/1/11 at 11:59 PM EST.
  • Detailed Image's best leather cleaner with light conditioners, perfect for maintaining leather
  • Restores oils and proteins that are naturally found in leather for a soft and supple feel
  • Cleans to a like new, matte finish that has no greasy or oily feel like other products
  • Apply to your leather and let sit for 15 - 30 minutes, wipe with a warm damp towel and buff dry
  • We recommend using a terry cloth application pad to help agitate the leather surface
  • For maximum results, Prestine Clean is best used after Leatherique Rejuvenator Oil
Detailed Image
Albany
This week's Weekly Special is DI Accessories Ultra Fine Clay Bar - 100 g.
Use Coupon Code WSULTRA0911 to receive it for Free. A $10.99 value! Min spend $30. Offer ends 3/8/11 at 11:59 PM EST.
Detailed Image
Albany
This week's Weekly Special is Chemical Guys Citrus Wash Wheel & Rim Cleaner .
Use Coupon Code WSCITRU1011 to receive it for Free. A $8.99 value! Min spend $45. Offer ends 3/15/11 at 11:59 PM EST.
  • Citrus based wheel cleaner that is safe to use on virtually any wheel surface
  • Concentrated solution makes this a great value as you can dilute it down 7:1 with water
  • Works best when an E-Z Detail Brush is used in conjunction with Wheel & Rim Citrus Cleaner
  • Protect your just cleaned wheels with Poorboy's World Wheel Sealant for easy maintenance
Detailed Image
Albany
This week's Weekly Special is 303 Aerospace Protectant - 16 oz.
Use Coupon Code WSAEROS1111 to receive it for Free. A $12.99 value! Min spend $60. Offer ends 3/22/11 at 11:59 PM EST.
  • An excellent UV protectant and dressing for vinyl, leather, rubber and plastic surfaces
  • Leaves behind a beautiful matte finish that is not greasy, shiny or oily
  • Treated surfaces resist dust, soiling, staining and also repel water
  • Most commonly used on interior dashboards, center consoles, door trim, leather seats, and in the engine bay
  • Works great on vinyl convertible tops, plastic rear windows, clear bras, and tonneau covers
  • For maximum efficiency use in a 4oz pump spray bottle and apply with a microfiber towel
Detailed Image
Albany
This week's Weekly Special is Meguiar's Ultra-Cut Compound M105 - 32 oz.
Use Coupon Code WSULTRA1211 to receive it for Free. A $26.99 value! Min spend $140. Offer ends 3/29/11 at 11:59 PM EST.
  • Very effective at cutting through deeper imperfections
  • Finishes down nicely, but we still recommend a finishing polish after 105
  • Commonly used with an orange light cutting pad, yellow cutting pad or purple foamed wool pad
Detailed Image
Albany
This week's Weekly Special is P21S Gel Wheel Cleaner - 500 ml Kit.
Use Coupon Code WSGELWH1311 to receive it for Free. A $17.99 value! Min spend $145. Offer ends 4/5/11 at 11:59 PM EST.
  • One of the safest, most effective, pH balanced wheel cleaners on the market
  • Gel based formula allows the product to penetrate vertical surfaces for a more effective cleaning
  • Perfect option for after market wheels as it is safe for virtually any wheel surface
  • Works best when an E-Z Detail Brush is used in conjunction with P21S Gel Wheel Cleaner
  • Follow up with Poorboy's World Wheel Sealant for wheels that are easier to maintain
Detailed Image
Albany
This week's Weekly Special is Meguiar's Ultra-Cut Compound M105 - 8 oz.
Use Coupon Code WSULTRA1411 to receive it for Free. A $9.49 value! Min spend $50. Offer ends 4/12/11 at 11:59 PM EST.
Detailed Image
Albany
This week's Weekly Special is SONAX Gloss Shampoo Concentrate - 1000 ml.
Use Coupon Code WSGLOSS1511 to receive it for Free. A $15.99 value! Min spend $95. Offer ends 4/19/11 at 11:59 PM EST.
  • pH neutral and phosphate free formula
  • Does not strip sealant or wax
  • Awesome value on a top quality auto shampoo
  • Pleasant scent makes it fun to use
Detailed Image
Albany
This week's Weekly Special is Stoner Tarminator - 10 oz.
Use Coupon Code WSTARMI1611 to receive it for Free. A $5.99 value! Min spend $30. Offer ends 4/26/11 at 11:59 PM EST.
  • Safely and effectively remove tar, grease and sap from painted surfaces
  • Simply spray Tarminator onto the effected area, let dwell for a minute or two, then wipe clean
  • Remember to protect the areas you use Tarminator on with a sealant or wax
Detailed Image
Albany
This week's Weekly Special is TUF SHINE Tire Clearcoat - 6 oz.
Use Coupon Code WSTIREC1711 to receive it for Free. A $24.99 value! Min spend $110. Offer ends 5/3/11 at 11:59 PM EST.
  • The longest lasting tire shine we have ever tested, lasts several months at a minimum
  • One coat gives you a beautiful matte finish, two coats gives you an incredibly dark and glossy finish
  • Water based formula with anti-static properties that repel dust
  • Does not use any petroleum solvents, silicones or oils that can attract dust
  • To get the Tire Clearcoat and more check out the TUF SHINE Tire Appearance Kit
  • Withstands several pressure washing treatments and can be washed with gentle cleaners
Detailed Image
Albany
This week's Weekly Special is Chemical Guys Maxi Suds II - 16 oz.
Use Coupon Code WSMAXIS1811 to receive it for Free. A $8.99 value! Min spend $45. Offer ends 5/10/11 at 11:59 PM EST.
  • One of our best selling shampoos, lots of foam, great lubricity, and gentle cleaning power
  • An addicting cherry scent that makes washing your car a pleasure
  • Best applied with a sheepskin wash mitt along with a Grit Guard bucket insert
  • High sudsing formula makes this a great option to use in foam guns
Detailed Image
Albany
This week's Weekly Special is Optimum Instant Detailer & Gloss Enhancer - 17 oz.
Use Coupon Code WSINSTA1911 to receive it for Free. A $9.99 value! Min spend $65. Offer ends 5/17/11 at 11:59 PM EST.
  • An outstanding quick detailer that enhances gloss and depth while increasing surface slickness
  • Easy to apply and remove streak free by misting into a plush microfiber towel and wiping your paint
  • Most commonly used after washing and drying your vehicle as a maintenance product
  • The 32oz and 128oz sizes are concentrated formulas to get even more bang for your buck
Detailed Image
Albany
This week's Weekly Special is DI Accessories E-Z Detail Brush - Full Size.
Use Coupon Code WSEZDET2011 to receive it for Free. A $21.99 value! Min spend $155. Offer ends 5/24/11 at 11:59 PM EST.
Detailed Image
Albany
This week's Weekly Special is Chemical Guys Synthetic Quick Detailer - 16 oz.
Use Coupon Code WSSYNTH2111 to receive it for Free. A $9.99 value! Min spend $50. Offer ends 5/31/11 at 11:59 PM EST.
  • A favorite quick detailer amongst professional detailers due to its outstanding shine and slickness
  • Works great as a clay bar lubricant
  • An ideal product to use after a wash to enhance the depth and gloss of your paint
  • We recommend using a plush microfiber towel to apply the Synthetic Quick Detailers
Detailed Image
Albany
This week's Weekly Special is DI Brushes Leather and Vinyl Scrub Brush.
Use Coupon Code WSLEATH2211 to receive it for Free. A $3.49 value! Min spend $15. Offer ends 6/7/11 at 11:59 PM EST.
  • Outstanding leather care brush to deep clean leather!
  • Works great with all leather care products, especially the Leatherique Prestine Clean and Leatherique Rejuvenator Oil
  • Soft and gentle leather brush that works great
Detailed Image
Albany
This week's Weekly Special is Menzerna Power Lock Polymer Sealant - 16 oz.
Use Coupon Code WSPOWER2311 to receive it for Free. A $29.99 value! Min spend $135. Offer ends 6/14/11 at 11:59 PM EST.
  • First true sealant produced by Menzerna
  • Long durable protection with a great shine!
  • Long lasting protection from durable polymer formula
  • Deep and glossy shine while easy to apply
Detailed Image
Albany
This week's Weekly Special is Chemical Guys Citrus Wash - 16 oz.
Use Coupon Code WSCITRU2411 to receive it for Free. A $9.99 value! Min spend $55. Offer ends 6/21/11 at 11:59 PM EST.
  • Ultra concentrated paintwork cleaning shampoo designed to strip off protection to start fresh
  • Powerful concentrated formula only requires 1oz of product per gallon of water to effectively remove layers of protection
  • Works well in a Gilmour Foam Gun
Detailed Image
Albany
Use Coupon Code WSULTRA2711 to receive it for Free. A $10.99 value! Min spend $30. Offer ends 7/12/11 at 11:59 PM EST.
Detailed Image
Albany
This week's Weekly Special is Chemical Guys Black Light Hybrid Radiant Finish.
Use Coupon Code WSBLACK2811 to receive it for Free. A $27.99 value! Min spend $160. Offer ends 7/19/11 at 11:59 PM EST.
  • Incredibly deep reflection that makes any color paint look great
  • Get the protection of a sealant with the gloss of a high end wax or glaze
  • WARNING Insane Gloss Levels!
  • Extremely easy to apply and remove
Detailed Image
Albany
This week's Weekly Special is DI Accessories Gentle Fine Grade Clay - 100 g.
Use Coupon Code WSGENTL3011 to receive it for Free. A $10.99 value! Min spend $40. Offer ends 8/2/11 at 11:59 PM EST.
Detailed Image
Albany
This week's Weekly Special is DI Brushes Boar's Hair Detailing Brush.
Use Coupon Code WSBOARS3111 to receive it for Free. A $15.99 value! Min spend $85. Offer ends 8/9/11 at 11:59 PM EST.
  • Use it to clean your wheels, exterior trim and so much of the interior
  • Ultra soft boar's hair fibers make it safe to use everywhere
  • Very durable design and fibers so you can use this brush for years
  • Helps clean tough to reach areas safely and easily
