New England Dragway, Epping NH 4/9/08
Old Poop
Goffstown, NH
I'm off to the drag races tonight and it is the first time I will be running on Nitto drag radials. I need advise. If you have experience with d/r's I would like some input on tire pressure and burnout technique. I am running a 93 with stock engine and exhaust. Transmission has been J-modded and has a cooler. Back tires are Nitto d/r 315/35x17.
Most posts I have read indicate anywhere from 14 to 20 psi on the rear and 55 psi one the front (Nitto d/r 275/40x17).
Most recommendations I have read for heating the tires is to back in to the waterbox, do a quick spin, pull out of the box and spin for about 7 seconds or until they start to smoke then, release the brake and let them run out a few feet.
I have also read that once staged, place the car in neutral, rev the engine once and when you feel the brake pedal sink a little more, place the transmission back in drive and load the torque converter to the almost ready to break loose condition.
If anyone can offer any more tips I would appreciate it.
It would be good to see some LvC members from the area there, gates open at 5pm.
(I like drag racing because I don't forget where I am going :D )
as for tire psi I do a burn out to see the tred pattren then change psi
and I have heard that with nittos if you burn them to long they will slip and slide
Thanks for the tip on watching the burn marks for the pattern and confirming that the short burn is better.
Do you have stock open diff? If so, only one tire will heat up so I don't know if it will help you to do a burnout.
