New Daily Specials at www.DetailedImage.com
Today's Daily special (January 21, 2010) is Chemical Guys Extreme Offensive Odor Eliminator - Concentrated.
Regular Price for 16 oz is $9.99. Today's price is $7.39!
  • Remove odors from your interior by killing the bacteria causing the foul smell
  • Powerful concentrated solution can be diluted down 2:1 with water and still maintain effectiveness
  • Leaves behind a fresh apple scent that lingers for days
  • To maximize your product, we recommend using a 4oz pump spray bottle to dispense
Today's Daily special (January 22, 2010) is Poorboy's World Quick Wax Plus (QW+).
Regular Price for 16 oz is $12.99. Today's price is $9.22!
  • Best applied just after washing to enhance the depth and gloss and protect the paint
  • Very easy to apply and remove when applied correctly
  • Applies in both the sun or the shade without difficult removal
  • Also works well on chrome, polished aluminum and wheels
  • Best applied with a plush microfiber towel to minimize any micro-marring in the paint
Today's Daily special (January 25, 2010) is Meguiar's Speed-Cut Compound M95.
Regular Price for 32 oz is $17.99. Today's price is $13.31!
  • Very effective at cutting through deeper imperfections
  • Follow up with a finer polish and pad combo, such as Meguiar's 205
  • Commonly used with an orange light cutting pad, yellow cutting pad or purple foamed wool pad
Today's Daily special (January 26, 2010) is Dodo Juice Red Mist Tropical Protection Detailer.
Regular Price for 250 ml is $16.99. Today's price is $12.57!
  • Extend the protection of any sealant or wax
  • Increase gloss and depth of your paint, perfect for after a wash
  • Promotes tight water beading which helps minimize water spots
  • Applies and removes easy with a plush microfiber towel
Today's Daily special (January 27, 2010) is Poorboy's World Natural Look.
Regular Price for 16 oz is $10.99. Today's price is $7.91!
  • An outstanding 1 step product that cleans, restores and UV protects
  • Works best on leather, vinyl, rubber, plastic, tires and more
  • Leaves behind a beautiful matte finish that is not greasy, shiny or oily
  • Best applied with a foam applicator pad and removed with a microfiber towel
Today's Daily special (January 28, 2010) is Lake Country Blue Grout Sponge.
Regular Price is $5.99. Today's price is $4.25!
  • One of the most popular used wash mediums by professional detailers
  • Very soft and durable, while being able to hold tons of suds and water helps reduce imperfections
  • One of the best features of the grout sponge is that it releases contamination very easily
  • For maximum results, use in combination with a Grit Guard bucket insert
Today's Daily special (January 29, 2010) is Lake Country Rotary Hook & Loop 5" Backing Plate.
Regular Price for 125 mm is $16.99. Today's price is $12.23!
  • Use with virtually any rotary buffer and 5.5" Hook and Loop Pads or larger
  • Get optimal results with the 5.5" Lake Country foam and wool pads
  • Allows you to easily put on new pads and pull of the old ones in just seconds
Today's Daily special (January 30, 2010) is Poorboy's World Trim Restorer.
Regular Price for 16 oz is $15.99. Today's price is $11.91!
  • Restores neglected rubber, vinyl and plastic trim that has faded over time
  • For maximum results, prep the trim you plan on restoring with a degreaser and apply multiple thin coats
Today's Daily special (January 31, 2010) is Optimum (OPT) Opti-Seal.
Regular Price for 8 oz is $24.99. Today's price is $17.99!
  • The ultimate in ease of use when it comes to protecting your vehicle with a sealant
  • Simply mist Opti-Seal onto your paint and walk away, no wiping is necessary when applied properly
  • Perfect for professional detailers or enthusiasts who are looking for maximum results in less time
Today's Daily special (February 1, 2010) is Optimum (OPT) Metal Polish.
Regular Price for 8 oz is $9.99. Today's price is $7.09!
Regular Price for 32 oz is $32.49. Today's price is $23.07!
  • Polish your metal to a high level of depth and gloss with the Optimum Metal Polish
  • Apply with a foam applicator pad and remove with a quality microfiber towel
  • Most commonly used on wheels, exhaust tips, interior and exterior metal and chrome trim
Today's Daily special (February 2, 2010) is Menzerna Power Gloss.
Regular Price for 16 oz is $18.99. Today's price is $14.15!
  • One of our most aggressive compounds we have to offer, allowing for deep paint correction
  • Most commonly used on a yellow cutting pad or purple foamed wool pad
  • Will leave behind marring and hazing, so it is important to follow up with a less aggressive polish
Today's Daily special (February 3, 2010) is Meguiar's Ultimate Quik Detailer.
Regular Price for 22 oz is $9.99. Today's price is $7.63!
  • Increases the depth and gloss of any color vehicle
  • Adds a layer of protection with high surface tension which repels water very well
  • Perfect product to use after a maintenance wash between details
Today's Daily special (February 4, 2010) is Poorboy's World Natty's Red Paste Wax.
Regular Price for 8 oz is $21.99. Today's price is $16.38!
  • One of the top performing carnauba waxes for under $25 and looks outstanding on any color
  • Leaves behind a ton of depth and gloss, especially when multiple coats have been applied
  • Easy to apply and remove when applied properly with a foam applicator pad and removed with a microfiber towel
Today's Daily special (February 5, 2010) is Optimum (OPT) Car Wax.
Regular Price for 17 oz is $14.99. Today's price is $10.94!
Regular Price for 128 oz is $39.99. Today's price is $28.79!
  • One of the best liquid waxes that is super easy to apply and remove, commonly used by pros
  • Perfect for maintaining your vehicles gloss and protection after a wash and dry
Today's Daily special (February 6, 2010) is DI Microfiber Micro-Restore Microfiber Detergent Concentrate.
Regular Price for 32 oz is $14.99. Today's price is $10.64!
Regular Price for 128 oz is $34.99. Today's price is $26.51!
  • Microfiber, cotton, chamois and towel revitalizer
  • Breaks down heavy wax, oil and grease
  • Contains no bleach or fabric softeners
  • Use 2 ounces for full loads or 1 ounce for smaller loads
  • Biodegradable
Today's Daily special (February 7, 2010) is Chemical Guys Blitz Acrylic Spray Sealant.
Regular Price for 16 oz is $17.99. Today's price is $12.77!
  • Easy to use, spray on sealant that adds protection and gloss to your paint
  • Works best after a maintenance wash to boost the protection of an existing coat of protection
  • To avoid over spray, we recommend misting Blitz into a plush towel, then wiping the paint
  • After Blitz has been applied, take a clean microfiber towel and buff away any streaks and residue
Today's Daily special (February 8, 2010) is Chemical Guys Grime Reaper A.P.C..
Regular Price for 16 oz is $7.99. Today's price is $5.67!
Regular Price for 128 oz is $24.99. Today's price is $18.49!
  • One of our most powerful degreasers available, designed to easily cut through contamination
  • Powerful concentrated solution can be diluted down 8:1 with water and still maintain effectiveness
  • Perfect to degrease wheel wells, engine bays, door jambs, tires and much more
  • Dilute into a 22oz empty spray bottle or a handy 4oz pump spray bottle
Today's Daily special (February 11, 2010) is Dodo Juice Light Fantastic Soft Wax.
Regular Price for 250 ml is $69.99. Today's price is $54.72!
Regular Price for 30 ml is $13.99. Today's price is $10.55!
  • A Dodo Juice soft carnauba wax designed to work exceptionally well on lighter colored vehicles
  • Extremely easy to apply and remove, especially when applied in thin layers
  • Strong protection and tight water beading makes maintaining your vehicle a breeze afterwards
  • Can be applied with a foam applicator pad or literally with your bare hands
  • Dodo Juice soft waxes offer slightly more depth and gloss over the Dodo Juice hard waxes
  • Remove any Dodo Juice wax with a plush microfiber towel
Today's Daily special (February 13, 2010) is Chemical Guys Clear Seal.
Regular Price for 16 oz is $8.99. Today's price is $6.56!
  • Clean, polish and protect all of your plastic surfaces, in one easy to use step
  • Leave plastic surfaces with a slick layer of protection to help minimize dust from building up
  • For accurate product dispensing, we recommend using a 4oz dispenser bottle and applying with a microfiber towel
Today's Daily special (February 14, 2010) is Lake Country Green Very Light Cutting Pad.
Regular Price for 6.5 inch is $9.99. Today's price is $7.29!
Regular Price for 5.5 inch is $8.99. Today's price is $6.47!
Regular Price for 4 inch is $4.99. Today's price is $3.64!
  • A very popular polishing pad designed to remove light surface imperfections from the paint
  • When you need a tad more bite than a white polishing pad, the green pad is your answer
  • Menzerna PO106FF polish is one of the most popular products to use with the green pad
  • We recommend caring for your pads with Snappy Clean Pad Cleaner
Today's Daily special (February 16, 2010) is Lake Country Hydro Tech Cyan Light Cutting and Polishing Pad.
Regular Price for 5.5 inch is $8.99. Today's price is $6.56!
Regular Price for 4 inch is $4.99. Today's price is $3.54!
  • Powerful cutting action but the ability to finish down haze free
  • Hydro Tech foam keeps more polish on the surface of the pad for long work time
  • Experience less dusting than traditional foam pads due to less product buildup
  • Save time and improve your results!
Today's Daily special (February 17, 2010) is Lake Country & Backing Plate for Porter Cable 7424.
Regular Price for 125 mm is $16.99. Today's price is $12.57!
  • Use with Porter Cable 7424 XP and 5.5" Hook and Loop Pads or larger
Today's Daily special (February 18, 2010) is DI Accessories Sheepskin Wash Mitt.
Regular Price is $9.99. Today's price is $7.39!
  • Perfect wash medium to help minimize adding swirls and other imperfections to the paint
  • The natural fibers help pull contamination away from the surface without grinding them in
  • When done using, rinse any contamination using free flowing water than hang dry with leather hoop
  • For best results, use in conjunction with a 2 bucket wash system utilizing Grit Guard Inserts
Today's Daily special (February 19, 2010) is Meguiar's Professional DA Polisher Backing Plate W67DA.
Regular Price for 5" is $19.99. Today's price is $14.89!
  • Soft core foam allows for easier maneuverability compared to stiffer backing plates
  • Works with any polisher with a 5/16th shaft (such as the Porter Cable 7424XP)
  • Durable one piece construction ensures a long life
  • Works best with 5.5" pads or larger
