New Daily Specials at www.DetailedImage.com
Today's Daily special (February 28, 2013) is Little Trees Royal Pine Air Freshener.
Regular Price is $0.99. Today's price is $0.70!
  • The original Little Trees scent that is still a favorite
  • Proudly made in the USA
  • Great scent that lasts several weeks
You can receive email notifications of our Daily Special each morning by signing up for a Detailed Image account
Today's Daily special (March 1, 2013) is DI Microfiber All Purpose Towel Yellow.
Regular Price for 16" x 16" is $3.99. Today's price is $2.87!
  • High quality yellow microfiber towel can apply or remove any product
  • Paint safe and extremely soft
  • Store microfiber products in a DI Accessories Reclosable Storage Bag to preserve them
  • Wash any microfiber product with the Chemical Guys Microfiber Wash Cleaning Detergent to enhance their longevity
  • Helps clean safely and effectively
Today's Daily special (March 4, 2013) is Stoner Invisible Glass.
Regular Price for 19 oz is $5.99. Today's price is $4.37!
  • Foam based glass cleaning formula that is ammonia free, making it safe on tinted windows
  • Easily removes oily dirt, dust, fingerprints, grease, adhesives, smudges, smoke haze and more from glass
  • Best applied with an all purpose microfiber towel, then wiped clean with a dry low nap microfiber towel
  • Do not apply in direct sunlight or hot glass, otherwise streaking may occur
Today's Daily special (March 5, 2013) is Dodo Juice Born Slippy Clay Lube Concentrate.
Regular Price for 250 ml is $12.99. Today's price is $10.94!
  • Ultra concentrated solution makes for over 2.5 liters of clay lube
  • Dilute up to a 10:1 ratio with water while remaining super slick
  • Wipes away streak free and is safe for nearly any surface
  • We recommend picking up a 22oz spray bottle for proper dilution
Today's Daily special (March 6, 2013) is Lake Country Purple Foamed Wool Pad.
Regular Price for 6 inch is $11.99. Today's price is $8.75!
Regular Price for 5 inch is $9.99. Today's price is $7.29!
Regular Price for 4 inch is $5.99. Today's price is $4.79!
  • Our most cutting pad option, however, due to the wool strands, not as much heat is generated
  • Works best on high powered buffers, for fast, effective paint correction
  • Commonly used with a medium or heavy cut compound to remove deep imperfections and wet sanding marks
  • We recommend caring for your pads with Snappy Clean Pad Cleaner
Today's Daily special (March 7, 2013) is DI Accessories Razor Blade Holder with Soft Grip.
Regular Price is $2.99. Today's price is $2.21!
  • Perfect way to hold your plastic or metal razor blades
  • Easy way to remove stickers from paint, glass, license plates, etc.
  • All standard razor blades will fit this holder
  • Made in the USA
Today's Daily special (March 8, 2013) is P21S Super-Absorbing Drying Towel.
Regular Price is $11.99. Today's price is $8.75!
  • High quality drying towel that soaks up large amounts of water
  • Made from 100% bio-degradable materials so it's environmentally friendly
  • Comes in an air tight plastic storage container which preserves the towel in between uses
  • German engineered to work great for years to come
Today's Daily special (March 11, 2013) is Menzerna Paint Refresh Professional Grade Detail Spray.
Regular Price for 22 oz is $23.99. Today's price is $17.75!
  • Cleans, shines, and protects your paint all in one step
  • Safe for painted surfaces, glass, plastic, chrome, etc.
  • Quickly removes dust, dirt, fingerprints, and light contamination
  • Leaves behind a layer of protection and anti-static properties
Today's Daily special (March 12, 2013) is DI Accessories Reclosable Storage Bag.
Regular Price for 24" x 24" is $2.99. Today's price is $2.12!
  • Simple solution for storing microfiber towels!
  • The large 24" x 24" size offers flexibility to accommodate dozens of towels
  • Thick reclosable bags make it a durable long term solution to storage needs
Today's Daily special (March 13, 2013) is DI Brushes Boar's Hair Detailing Brush.
Regular Price for 1" is $15.99. Today's price is $11.67!
Regular Price for 1.25" is $17.99. Today's price is $13.89!
  • Use it to clean your wheels, exterior trim and so much of the interior
  • Ultra soft boar's hair fibers make it safe to use everywhere
  • Very durable design and fibers so you can use this brush for years
  • Helps clean tough to reach areas safely and easily
Today's Daily special (March 14, 2013) is Chemical Guys Black Light Hybrid Radiant Finish.
Regular Price for 16 oz is $25.99. Today's price is $18.97!
  • Incredibly deep reflection that makes any color paint look great
  • Get the protection of a sealant with the gloss of a high end wax or glaze
  • WARNING Insane Gloss Levels!
  • Extremely easy to apply and remove
Today's Daily special (March 15, 2013) is Meguiar's DA Microfiber Cutting Disc Buffing Pad - 2 pack.
Regular Price for 5.5" is $21.99. Today's price is $16.05!
Regular Price for 6.25" is $23.99. Today's price is $17.87!
Regular Price for 3" is $13.99. Today's price is $10.42!
  • Combine this pad with the Meguiar's DA Microfiber Correction Compound for best results
  • Includes 2 Pads
  • Exceptional cutting power that removes swirls while finishing down crystal clear
  • A brand new technology that is changing the detailing world
  • Use a Porter Cable 7424 XP and the Meguiar's Professional Backing Plate
Today's Daily special (March 18, 2013) is DI Accessories Yellow Foam Applicator Pad.
Regular Price is $1.49. Today's price is $1.07!
  • Most commonly used for applying polishes, glazes, sealants, and waxes!
  • Helps you apply a thin and even coating over any surface for maximum results
  • Washable and reusable so they provide a great value for years to come
Today's Daily special (March 19, 2013) is Little Trees New Car Air Freshener.
Regular Price is $0.99. Today's price is $0.73!
  • Instantly reminds you of the new car smell that is clean and fresh
  • Amazing scent that easily lasts several weeks
  • One of the most popular Little Trees scents
Today's Daily special (March 20, 2013) is Optimum No Rinse Wash & Shine (ONR).
Regular Price for 32 oz is $15.99. Today's price is $11.35!
Regular Price for 128 oz is $39.99. Today's price is $29.19!
  • New formula launched in 2012 with more gloss, slicker feel and it releases contaminants better
  • Properly wash your car without the need for a hose or rinsing your vehicle
  • Use as a quick detailer and clay bar lubricant, mix 1 oz of ONR to 16oz of water
  • Favorite product of many high end detailers
  • Perfect for detailing on the go, those living in apartment complexes, washing in the winter, mobile detailing, etc.
Today's Daily special (March 21, 2013) is TUF SHINE Tire Brush.
Regular Price is $4.99. Today's price is $3.64!
  • Great for deep cleaning the tires
  • Use with the TUF SHINE Tire Cleaner or your favorite degreaser
  • Strong yet gentle bristles
  • Cleaning your tires is critical before applying any tire dressing, especially the TUF SHINE Tire Clearcoat
Today's Daily special (March 22, 2013) is SONAX Profiline Nano Polish 3/6.
Regular Price for 1000 ml is $47.99. Today's price is $34.55!
  • Excellent polishing power but still finishes down extremely well
  • Works great as a one step polish or pair it with the SONAX Profiline Fine Abrasive Paste 5/4 for serious polishing power
  • Safely removes swirls, oxidation, water marks, ultra fine scratches, etc.
  • Has the polishing power of a medium cutting polish but finishes down like a premium fine polish should
  • Low dusting, easy to use, easy to remove
Today's Daily special (March 26, 2013) is Menzerna Fast Gloss 400 Compound.
Regular Price for 16 oz is $29.99. Today's price is $22.34!
Regular Price for 32 oz is $49.99. Today's price is $37.24!
  • Easily remove heavy imperfections while leaving behind a high gloss finish!
  • Apply with a cutting pad (i.e. Lake Country Orange Light Cutting Pad, Surbuf R Series MicroFingers Buffing Pads or Optimum Microfiber Cutting Pad)
  • Very low dusting which makes for easy cleanup
  • On darker finishes follow up with a finer Menzerna polish like the Power Finish PF 2500, Super Finish Polish SF 4000 or Micro Polish SF 4500
  • Premium medium to heavy cutting polish, that finishes down extremely well!
Today's Daily special (March 27, 2013) is SONAX Leather Foam.
Regular Price for 400 ml is $14.99. Today's price is $11.09!
  • Cleaner, conditioner and protectant in one bottle
  • Foam action makes it excellent for perforated seats
  • Works on leather and leatherette seats
Today's Daily special (March 28, 2013) is Chemical Guys Black on Black.
Regular Price for 11 oz is $12.99. Today's price is $9.35!
  • One of the most unique trim restorers that turns faded trim back to a deep factory black finish
  • Perfect option for wheel wells, engine bay dressing, tire dressing and exterior trim pieces
  • Formerly referred to as Chemical Guys Fade 2 Black
Today's Daily special (March 29, 2013) is DI Accessories DetailedImage.com License Plate Frame.
Regular Price is $5.99. Today's price is $4.37!
  • Black DetailedImage.com license plate frame with white lettering
  • "Clean Shine Protect" tag line
  • Thank you for your support!
Today's Daily special (April 1, 2013) is DI Brushes Toothbrush Style Detail Brush.
Regular Price is $1.99. Today's price is $1.45!
  • Remove dirt and debris from small seams and crevices safely and easily!
  • Easy to grip plastic handle with grooved "finger-grips"
  • Soft and safe horse hair bristles
  • Durable construction for regular usage
Today's Daily special (April 2, 2013) is Optimum No Rinse Wash & Wax.
Regular Price for 32 oz is $19.99. Today's price is $14.39!
Regular Price for 128 oz is $49.99. Today's price is $35.49!
  • Wash and wax your car without the need to rinse your vehicle!
  • ONR + Wax = Perfection in one bottle
  • Safely remove contaminants, protect the paint and no drying is needed
  • Perfect for those in apartment complexes, mobile detailers, frequent travelers and winter washes
Today's Daily special (April 3, 2013) is DI Brushes Fender and Grill Brush.
  • Safely remove built up dirt and grime from your grill
  • Soft natural tampico bristles will not mar or scratch the surface
  • 8.5" durable foam block handle
Today's Daily special (April 4, 2013) is DI Accessories Plastic Razor Blade.
  • Perfect to use on windows!
  • Fits all standard razor blade holders
  • Single edged design
  • Quickly remove inspection stickers and registration stickers!
