mikenjulie2
Hello everyone. My name is Mike just wanted to say hello, and that this is a great website with lots of good info. I just bought a 2000 ls v6 sport package with 104k for my son. I didn't realize how much fun I was going to have working on it, until I started reading the forum. A few issues that I didn't find answers to using the search button. ( New here, but not to forums
1) advancetrac icon on dash stays on constantly, the button on center console is inoperable, and previous owned said it was blowing a fuse as soon as he put a new one in. I'm guessing there's a short somewhere, or the switch itself is bad? Any thoughts?
2) Moonroof will pop up and close normally. When I try to open completely, it will start to slide back, but only about an inch and then stops. I've pulled the headliner, but can't see anything that would cause it. I've greased the tracks and thought maybe the alignment is off? That even possible?
3) Heated seat switches appear to not be working. Fuse is good. Haven't pulled dash apart, but wondered if the heated seat switches could both go bad? One module control both? The cigarette lighter works though.
Any info would be appreciated. I've already reconnected the moonroof drain tubes and zip tied them. Replaced about 5 bulbs that were burned out. Ordered 2 new adjust link for rear suspension.
I have to say I had a mitsubishi evo and the guys and gals on that forum were great. I've been on several other forums, and this is the only one that has come close to having the same info/insight that I'm used to. Thanks again all, and thanks for having me.
Mike
Mike
