need wiring diagram for 95 amp
I had no problems taping from the amp in my 97
You do know your speaker wires come from the amp right
Good fuggin greif. If you tap FROM the amp then you will be dealing with the amps x-overs and internal EQ plus its very high THD. If you get your sub signal BEFORE the amp from the deck then you wont have that added distortion or the automatic reduced bass level the amp does at higher volumes to save the 6x8 "woofers".
While it will "work" it will not work well or near its abilities. It will perform much better if the signal is taken before the amp.
Laser that's why I want the wiring diagram
So I can see what wires I need
I'm sorry I wrote from and not to
Thanks stu
