need some codes interpreted
P0401 - Insufficient EGR flow (usially means vacuul leak in EGR engagement or dirty EGR valve).
P2C59 - ?? Are you shure? Codes ends P1xxx...
P04E0 - E0 - can't be, according to SM by Ford.
wow ok...so I took it to two different places only code was the EGR code, not to worried about that don't have one, but the car still has a hard time with cold starts. I also cleaned the MAF, seafoamed the gas tank and engine and did the fuel filter.
If you illiminate the EGR system wihout the "chip-tune" this code will be anyway, it will become your best friend and will always lit up your CE lamp. It can become a problem, 'cause you will not be able to determine visually, what codes do you have, and will have to read codes regulaly to ceap you car healthy.
And I really don't know (and the Service manual don't) what the other two means...
the other 2 arent "real" codes ive seen this a lot on here some cheap code puller will give a real code then some gibberish all ford obd2 codes are a letter then 4 numbers ex. p0301, cyl 1 miss, p0401 egr insufficient flow etc etc etc if it isnt layed out like that its not real or the puller is junk
