Need part number for vacuum harness
tireman
atlanta
2001 V6 3.0L The vacuum harness connects to the EGR valve then travels back to the EGR vacuum valve then to the back of the intake manifold for suction. I have found plenty of parts for the F150 that look identical, however it says they are not compatible. So does anyone know the manufacturer part number? Thanks
Tried a quick search at a couple online places. Didn't see anything.
Call your local dealer parts department. Or... go to your local parts store and get a few lengths of vacuum tubing that matches what is on the car.
For neatness... you could get some wire loom sleeve tubing... and slip it on the new vacuum lines.
I am familiar with those vacuum lines. They are the hard plastic type which transition to rubber elbows that connect to the devices. Once they crack or otherwise break, you'll probably have to just find properly sized rubber vacuum hose and make it work that way. My PCV line from the rear of the engine to the throttle body had a broken rubber terminator in the transition from plastic to rubber and those parts are no longer available new. Vacuum line made of rubber should work in your case.
There is another option I didn't think of initially.
Go to a junkyard/salvage yard near you... and look for a 1st generation LS with the V6.
Look for one with the hood closed... or at least one not facing the sun all day. The suns UV rays will deteriorate those plastic lines too.
Grab a couple sets if you can... but be gentle pulling them off the engine. You may get lucky with one set... or be able to piece together a good set out of 2.
They should be cheap... because junkyards don't know or care about those lines having issues.
many thanks but i know it is out there because the ford f150 has the same looking harness and there are plenty available, i may have to buy the f150 harness and just modify the length of hose line. The f150 harness is about $20 online.
