Need help with wires/plugs
Shamarlong32
Lncoln Nebraska
I recently was told I needed to clean my EGR valve, well as I started to remove the stupid nut in the back i came down hard with the wrench and snapped one of my plugs to the fuel pressure vacuum or sensor. I've tried looking everywhere but can't find anything.
I would get a shop manual first.
Plenty of them on EBay. Printed and on CD.
Then I would concentrate on finding out the factory part number and see what you can find. Now with the age of the car you might only have used parts available or have to fix up something yourself.
Can you DIY the repairs?
Year? V6 or V8? and a picture of the part with location in the engine bay may help us with service manuals identify the part number for you. You can also search https://car-part.com
I ended up figuring it out, turns out it was just the simple plastic piece that sits on the fuel pressure sensor that broke off into a piece of hosing. so I tried prying it out and couldn't get it, so my final attempt was using a screw and put it inside the plastic piece that was stuck and pulled it out. now my new problem is that my seat reclines but doesn't go up and I'm somehow getting water inside the driver pillar up towards the sun roof, but no visible entry to allow the water to come in.
