My 06 lincoln has 52,000 miles, and have run into a major issue... It overheats all the time, did a pressure test and found a leak, and got it fixed..Even with the leak sealed and no coolant leaking the car will over heat and the reserve tank will have the coolant boiling.. *quick note* my buddy was trying to pull out the thermostat and broke it so running the car with no stat.. Would this be the reason why my car is overheating. I have been told it could also be the fact that i did not bleed the cooling system and have air in the lines.But the car will not over heat if I have the heater running ..
Any ideas?
Any ideas?
