Couple of months ago i did some suspension work, after which my brakes started playing up. I spoke about it with frogman and he suggested some stuff, which i did to no avail. The problem was i had a good, hard pedal but only partial brake power front and rear. Anyway i suspected kinked lines between the m/cyl and the junction behind the headlight as these were the only ones disturbed when i did the uppers. Today i changed those lines, bled the system and i STILL have the exact same problem! The vacuum booster is good and the check valve works. The pads and discs are recent. Any ideas? Its driving me crazy! Thanks. Martin.
