Need help 98' my brake light and signal problem
REDDNOZE
MATTESON
my rear window brake light and tail lights work but brake lights dont the bulbs and fuses are fine does anyone know what is wrong or how i could fix this problem
Same Problem Here
I am having the exact same problem. But my vehicle is a 2000 Lincoln LS. Any suggestions ??
I am having a problem like that too. My driver's brake light goes out when it gets cold outside. It's not the bulb or fuse...Any suggestions?
Couple of questions:
When you turn your lights on, do all your rear lights (excluding the rear window/third brake light) up?
If so, what happens to the lights when you push the pedal in? Does your rear window/third brake light up?
