need an answer please.
BAD97LSC
Palm Harbor FL
i have a motor from a 97 a guy is interested in, he has a 97 cobra with a bad motor, he wants a temp motor ( mine ) while he has his built, question he needs to know is, what does he have to get for a flywheel tomake his 5 speed work on the mark crank, is a gt crank a 6 bolt like the mark VIII? his is an 8 bolt crank so he cannot put his flywheel and clutch on my motor, but we need to know what can he put on my crank, to make his 5 speed work. any help is much appreciated.
He will need to have a flywheel drilled with the Mark Vlll bolt pattern and have it zero balanced. I am almost certain that the starters run the same teeth.
