went to autozone and had code of <PO153 slow response bank 2 sensor 1 ckt> i'm about to order from max the o2 sensor. he said i need the one that is pre-cat. is this true and where is it and is it easy to get to on this car? 2000 ls v8. also my regulator crapped out again in pass. rear window. when i changed the front driver's side i ordered it from max and it came w/ the motor on so it was easy. you could order just the regulator on the rear window but i don't want to mess w/ rivets and stuff to put new motor on new regulator. what's the difficulty on that one? should i just order the regulator alone? thanks in advance. board is always icredibly helpful.:Beer
